Salta al contenuto principale
HP Pavilion dv1000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion dv1000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Shut down the computer.
    • Disconnect all external devices and cables from the computer.
  2. HP Pavilion dv1000 Keyboard Replacement: passo 2, immagine 1 di 1
    • Flip the laptop over.
  3. HP Pavilion dv1000 Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion dv1000 Keyboard Replacement: passo 3, immagine 2 di 2
    • Locate the gray sliding tab next to the black bar where the battery is located.
    • Slide the gray sliding tab to the left until you hear a distinct click.
    • The inside edge of the battery should pop up.
  4. HP Pavilion dv1000 Keyboard Replacement: passo 4, immagine 1 di 3 HP Pavilion dv1000 Keyboard Replacement: passo 4, immagine 2 di 3 HP Pavilion dv1000 Keyboard Replacement: passo 4, immagine 3 di 3
    • Grasp the inside edge of the battery.
    • Lift the inside edge of the battery up to detach the battery from the laptop.
  5. HP Pavilion dv1000 Keyboard Replacement, Keyboard: passo 5, immagine 1 di 1
    • Remove the highlighted screws.
    • After removing the screws, flip the laptop over.
  6. HP Pavilion dv1000 Keyboard Replacement: passo 6, immagine 1 di 2 HP Pavilion dv1000 Keyboard Replacement: passo 6, immagine 2 di 2
    • Open the laptop.
    • Use the spudger to lift the keyboard.
    • Do not pull the keyboard up and away from the computer, because it is still attached by a ribbon cable.
    • Press the two white clips forward with your fingers and gently pull the ribbon from the clips.
Conclusione
Tyler Latour
Membro da: 03/12/14
266 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,619
