Salta al contenuto principale
HP Pavilion dm4-1265dx Wi-Fi Card Replacement
Cosa ti serve
  1. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 2, immagine 1 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 2, immagine 2 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 2, immagine 3 di 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Back Panel: passo 3, immagine 2 di 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 4, immagine 1 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 4, immagine 2 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 4, immagine 3 di 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: passo 5, immagine 1 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: passo 5, immagine 2 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement, Wi-Fi Card: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using ESD safe tweezers, gently disconnect the black and white wires connecting the Wi-Fi card to the device.
    • Move the wires out of the way to allow the Wi-Fi card to spring up without obstructions.
  6. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 6, immagine 1 di 2 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 6, immagine 2 di 2
    • Remove the two 3.0 mm screws from the Wi-Fi card using a Phillips #0 screwdriver.
  7. HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 7, immagine 1 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 7, immagine 2 di 3 HP Pavilion dm4-1265dx Wi-Fi Card Replacement: passo 7, immagine 3 di 3
    • The Wi-Fi card will spring upwards.
    • Gently remove the Wi-Fi card by pulling it away from its socket.
Conclusione
Mason Hall
Membro da: 03/24/22
231 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 237
