Salta al contenuto principale
HP Pavilion dm4-1265dx RAM Replacement
Cosa ti serve
  1. HP Pavilion dm4-1265dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx RAM Replacement: passo 2, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 2, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 2, immagine 3 di 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx RAM Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion dm4-1265dx RAM Replacement, Back Panel: passo 3, immagine 2 di 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 4, immagine 3 di 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx RAM Replacement, RAM: passo 5, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement, RAM: passo 5, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement, RAM: passo 5, immagine 3 di 3
    • Push the two clips on either side of the top RAM stick away from each other.
  6. HP Pavilion dm4-1265dx RAM Replacement: passo 6, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 6, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 6, immagine 3 di 3
    • Pull the top RAM stick upwards.
    • The RAM stick should be at an angle to the device.
    • Gently pull the RAM stick away from the socket.
  7. HP Pavilion dm4-1265dx RAM Replacement: passo 7, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 7, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 7, immagine 3 di 3
    • Push the two clips on either side of the lower RAM stick away from each other.
  8. HP Pavilion dm4-1265dx RAM Replacement: passo 8, immagine 1 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 8, immagine 2 di 3 HP Pavilion dm4-1265dx RAM Replacement: passo 8, immagine 3 di 3
    • Pull the lower RAM stick upwards.
Conclusione
Ethan Redfern
Membro da: 03/29/22
133 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 228
