Salta al contenuto principale
HP Pavilion dm4-1265dx Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion dm4-1265dx Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 2, immagine 3 di 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion dm4-1265dx Hard Drive Replacement, Back Panel: passo 3, immagine 2 di 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, immagine 1 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, immagine 2 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 4, immagine 3 di 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • Loosen the single captive screw holding the hard drive cover in place using a Phillips #0 screwdriver.
    • Lift the hard drive cover away and up to remove.
  6. HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion dm4-1265dx Hard Drive Replacement: passo 6, immagine 3 di 3
    • Lift the hard drive out of the device from the connector side.
    • Grasp the connector and pull it out of the hard drive.
    • Remove the hard drive from the laptop.
Conclusione
Matthew Walter
Membro da: 03/29/22
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 364
