Salta al contenuto principale
HP Pavilion dm4-1265dx Clock Battery Replacement
Cosa ti serve
  1. HP Pavilion dm4-1265dx Clock Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over so the bottom is facing up.
  2. HP Pavilion dm4-1265dx Clock Battery Replacement: passo 2, immagine 1 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement: passo 2, immagine 2 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement: passo 2, immagine 3 di 3
    • Push the sliding lock to release the battery.
    • Remove the battery by lifting it away from the device.
  3. HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion dm4-1265dx Clock Battery Replacement, Back Panel: passo 3, immagine 2 di 2
    • Orient the device so that the empty battery port is closest to you.
    • Loosen the two captive screws holding the back panel in place using a Phillips #0 screwdriver.
  4. HP Pavilion dm4-1265dx Clock Battery Replacement: passo 4, immagine 1 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement: passo 4, immagine 2 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement: passo 4, immagine 3 di 3
    • Pull back and lift the back panel to remove it from the device.
  5. HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: passo 5, immagine 1 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: passo 5, immagine 2 di 3 HP Pavilion dm4-1265dx Clock Battery Replacement, Clock Battery: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • The clock battery is a metallic disk near the battery port. The words "Lithium 3V" are on the face.
    • Disconnect the battery from the metallic fasteners using the tweezers.
    • Slightly bend the fasteners away from the battery.
    • Pick up the battery with the tweezers and dislodge from the fasteners.
  6. HP Pavilion dm4-1265dx Clock Battery Replacement: passo 6, immagine 1 di 1
    • Fully remove battery from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 376
