Salta al contenuto principale
HP Pavilion Wave 600-a014 System Fan Replacement
Cosa ti serve
  1. HP Pavilion Wave 600-a014 System Fan Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 System Fan Replacement: passo 2, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 2, immagine 2 di 2
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 System Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 3, immagine 2 di 2
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 System Fan Replacement: passo 4, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 4, immagine 2 di 2
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 System Fan Replacement: passo 5, immagine 1 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 5, immagine 2 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 5, immagine 3 di 3
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 System Fan Replacement: passo 6, immagine 1 di 1
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
  7. HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: passo 7, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement, System Fan: passo 7, immagine 2 di 2
    • After removing your hard drive, remove the two 1.2mm Phillips #1 screws from the bottom of your case .
  8. HP Pavilion Wave 600-a014 System Fan Replacement: passo 8, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 8, immagine 2 di 2
    • Remove the 8 mm Phillips #0 screw that is connected the top bezel and the top cover using the driver kit.
  9. HP Pavilion Wave 600-a014 System Fan Replacement: passo 9, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 9, immagine 2 di 2
    • Using a flathead screwdriver, remove the 8 mm Phillips #1 screw that connects the body casing and the top bezel(the one at the bottom of memory card slot).
  10. HP Pavilion Wave 600-a014 System Fan Replacement: passo 10, immagine 1 di 1
    • Remove the top bezel.
    • You will have to take off a pair of wire connecting the bezel with the body to be able to completely detach it.
  11. HP Pavilion Wave 600-a014 System Fan Replacement: passo 11, immagine 1 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 11, immagine 2 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 11, immagine 3 di 3
    • Turn the device to the top side where you can see the top cover and the speaker.
    • Using a flathead or Phillips #1 screwdriver, unscrew all the eight 8.0 mm screws that connect the top cover to the other components of the casing.
    • Gently remove the top cover.
  12. HP Pavilion Wave 600-a014 System Fan Replacement: passo 12, immagine 1 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 12, immagine 2 di 3 HP Pavilion Wave 600-a014 System Fan Replacement: passo 12, immagine 3 di 3
    • After removing the top cover, locate the system fan on the left side of memory compartment.
    • Remove three 1.2 cm Phillips #1 screws that connect the fan with the main body.
  13. HP Pavilion Wave 600-a014 System Fan Replacement: passo 13, immagine 1 di 2 HP Pavilion Wave 600-a014 System Fan Replacement: passo 13, immagine 2 di 2
    • Simply slide up the fan after removing the screws.
Conclusione
Kyaw Soe
Membro da: 09/27/17
321 Reputazione
2 Guide realizzate
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro di Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,149
