Salta al contenuto principale
HP Pavilion Wave 600-a014 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion Wave 600-a014 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Disconnect the PC from power source and any other devices.
  2. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Turn the computer over and remove the rubber feet.
    • Remove the three 8mm Philips screws with a Philips #0 Screwdriver.
    • Use a pry tool and lift up on the lid.
  3. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the two cables circled in red for the front IO panel.
  4. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 4, immagine 2 di 2
    • From back IO panel pry open the casing as indicated.
  5. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 5, immagine 3 di 3
    • To remove the hard drive, remove the four 8mm Philips screws using a Philips #0 Screwdriver.
    • Remove Power and SATA cables from on top of the drive.
  6. HP Pavilion Wave 600-a014 Hard Drive Replacement: passo 6, immagine 1 di 1
    • After screws have been removed grab the Hard Drive and pull it out of the dock.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S8-G4, Banghart Fall 2017 Membro di Cal Poly, Team S8-G4, Banghart Fall 2017
CPSU-BANGHART-F17S8G4
4 Membri
5 Guide realizzate
2 Commenti
Hi there, can you advise whether this was the 128gb SSD or the other 2gb drive?
Joey Franco - Replica
This model comes with a 3.5" 1TB HDD standard.
Jay Marble -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 43
Tutti i Tempi: 2,382
