Salta al contenuto principale
HP Pavilion Wave 600-a010 hard drive Replacement
Cosa ti serve
  1. HP Pavilion Wave 600-a010 hard drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 hard drive Replacement: passo 2, immagine 1 di 1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 hard drive Replacement: passo 3, immagine 1 di 1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 hard drive Replacement: passo 4, immagine 1 di 1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 hard drive Replacement: passo 5, immagine 1 di 2 HP Pavilion Wave 600-a010 hard drive Replacement: passo 5, immagine 2 di 2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 hard drive Replacement: passo 6, immagine 1 di 2 HP Pavilion Wave 600-a010 hard drive Replacement: passo 6, immagine 2 di 2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 hard drive Replacement: passo 8, immagine 1 di 2 HP Pavilion Wave 600-a010 hard drive Replacement: passo 8, immagine 2 di 2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
Conclusione
Altre 5 persone hanno completato questa guida.
2 Commenti
Why isn't there any information regarding cloning or transferring the original HDD and RECOVERY (D:) partition to the SSD. After my ssd upgrade I tried to use the recovery media and it would not work.. The portion or removal and replacing was pretty much spot on especially if you have done this type of thing before. (At least in my opinion)
CERB - Replica
Were you able to clone the HDD to your SSD? How about recovery? Also, is it possible and are there enough room for SSD and HDD? Please share your experience. Thank you!
thomastranrx - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,164
