Introduzione
This guide will help give direction to properly remove the speaker from your HP Pavilion Wave Desktop PC. Tools required for this removal include Phillips and Torx head screwdrivers, metal and plastic prying tools, and a magnetic arrangement pad.
Cosa ti serve
Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
Remove the three 24 mm screws that connect the top cover to the chasis inside the HDD compartment using theTorx #15 screwdriver (an extension and torque lever might be useful).
Remove the top chassis cover from the main chassis using the Torx Head #15 screwdriver to remove the nine 24 mm screws and then use the metal prying tool to pry the top chassis cover from the clips holding it to the main chassis and lift carefully away from internal components.
