Salta al contenuto principale
HP Pavilion Wave 600-a010 Speaker Replacement
Cosa ti serve
  1. HP Pavilion Wave 600-a010 Speaker Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove the three rubber footings by prying from the bottom cover using the plastic opening tool.
  2. HP Pavilion Wave 600-a010 Speaker Replacement: passo 2, immagine 1 di 1
    • Remove the three 24 mm screws from the bottom cover using a Phillips #2 screwdriver.
  3. HP Pavilion Wave 600-a010 Speaker Replacement: passo 3, immagine 1 di 1
    • Remove the bottom cover by lifting it up from chassis.
  4. HP Pavilion Wave 600-a010 Speaker Replacement: passo 4, immagine 1 di 1
    • Remove the three wires connecting the outer cover and front I/O port to the internal components (front usb and auxiliary assembly).
  5. HP Pavilion Wave 600-a010 Speaker Replacement: passo 5, immagine 1 di 2 HP Pavilion Wave 600-a010 Speaker Replacement: passo 5, immagine 2 di 2
    • Remove the outer cover by gently pulling apart and pulling away from the chassis.
  6. HP Pavilion Wave 600-a010 Speaker Replacement: passo 6, immagine 1 di 2 HP Pavilion Wave 600-a010 Speaker Replacement: passo 6, immagine 2 di 2
    • Remove rear I/O bezel using plastic opening tool to pry apart the four clips holding the I/O bezel to the chassis.
    • Remove all other remaining cables from unit using the plastic opening tool to carefully pry apart the connections.
  7. HP Pavilion Wave 600-a010 Speaker Replacement: passo 8, immagine 1 di 2 HP Pavilion Wave 600-a010 Speaker Replacement: passo 8, immagine 2 di 2
    • Remove the HDD by first using the Phillips #2 screwdriver to remove the four 23 mm screws holding together the assembly and then pulling the HDD out of the chassis.
  8. HP Pavilion Wave 600-a010 Speaker Replacement, Microphone: passo 9, immagine 1 di 1
    • Remove the three 24 mm screws that connect the top cover to the chasis inside the HDD compartment using theTorx #15 screwdriver (an extension and torque lever might be useful).
  9. HP Pavilion Wave 600-a010 Speaker Replacement: passo 10, immagine 1 di 1
    • Disconnect the microphone computer chip from the internal components by first peeling away the black adhesive holding the wires to the chassis and gently pulling the chip and wires from its connection.
  10. HP Pavilion Wave 600-a010 Speaker Replacement: passo 11, immagine 1 di 2 HP Pavilion Wave 600-a010 Speaker Replacement: passo 11, immagine 2 di 2
    • Remove the top bezel from the unit using a Torx Head #15 screwdriver to remove three 24 mm screws and a Phillips Head #00 screwdriver to remove the single 24 mm screw around the outside edge of the chassis.
  11. HP Pavilion Wave 600-a010 Speaker Replacement, Speaker: passo 12, immagine 1 di 2 HP Pavilion Wave 600-a010 Speaker Replacement, Speaker: passo 12, immagine 2 di 2
    • Remove the top chassis cover from the main chassis using the Torx Head #15 screwdriver to remove the nine 24 mm screws and then use the metal prying tool to pry the top chassis cover from the clips holding it to the main chassis and lift carefully away from internal components.
  12. HP Pavilion Wave 600-a010 Speaker Replacement: passo 13, immagine 1 di 3 HP Pavilion Wave 600-a010 Speaker Replacement: passo 13, immagine 2 di 3 HP Pavilion Wave 600-a010 Speaker Replacement: passo 13, immagine 3 di 3
    • Remove the speaker by removing three 24 mm screws using the Torx Head #15 screwdriver and carefully lifting up and out from internal components.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 661
