Salta al contenuto principale
HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement
Cosa ti serve
  1. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Battery: passo 1, immagine 1 di 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove back plate: passo 2, immagine 1 di 1
    • Using a spudger, pry the plastic plate off of the base of the computer.
  3. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove screws: passo 3, immagine 1 di 1
    • Remove the screws from the WLAN card
  4. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove WLAN card: passo 4, immagine 1 di 1
    • Remove the card by sliding out of the slot.
  5. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Disconnect the cables: passo 5, immagine 1 di 1
    • Remove the cables from their connections by pulling them off. They should snap on and off.
Conclusione
Nguyen
Membro da: 01/22/15
301 Reputazione
2 Guide realizzate
Cal Poly, Team 21-22, Maness Winter 2015 Membro di Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 447
