Salta al contenuto principale
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 3, immagine 1 di 1
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 4, immagine 1 di 1
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 5, immagine 1 di 1
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: passo 6, immagine 1 di 1
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 21-22, Maness Winter 2015 Membro di Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Membri
6 Guide realizzate
Un commento
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,656
