Salta al contenuto principale
HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Wedge your finger (or tool) in between the outer plastic cover of the laptop and the main part of the laptop.
    • Pry the outer plastic cover off of the laptop.
    • Prying the outer plastic cover off may take a significant amount of force.
  3. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Unscrew all screws that surround the hard drive with a Philip Head
  4. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 4, immagine 2 di 2
    • Carefully lift the hard drive up by holding the tag shown here.
  5. HP Pavilion Touchsmart 11z-e000 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Remove the final attachment to the hard drive located at the end shown here.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 21-22, Maness Winter 2015 Membro di Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 2,955
