Salta al contenuto principale
HP Pavilion Touchsmart 10-e010nr Battery Replacement
  1. HP Pavilion Touchsmart 10-e010nr Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Power off device and place with battery facing up.
    • Ensure that your hands are not wet, even if the laptop is off or dead.
  2. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 2, immagine 1 di 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 2, immagine 2 di 2
    • Push slider on left-hand side of device into unlocked position. This slider is not spring loaded so it should stay in position afterwards.
  3. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 3, immagine 1 di 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 3, immagine 2 di 2
    • Push in right-hand slider with your thumb and simultaneously apply slight pressure away from your body.
    • It may be helpful to keep your left thumb on the left slider and push with both thumbs.
  4. HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 4, immagine 1 di 2 HP Pavilion Touchsmart 10-e010nr Battery Replacement: passo 4, immagine 2 di 2
    • Battery should easily separate from main device.
Conclusione
Sean
Membro da: 09/17/18
159 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 489
