Salta al contenuto principale
HP Pavilion TouchSmart 14z-n100 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove these two, 4 mm long number 1 Phillips screws from the device.
  2. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 2, immagine 1 di 1
    • Gently pull the keyboard up with a small plastic opening tool, beginning toward the front right corner. Just pull the keyboard up enough to fit your fingers under.
  3. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 3, immagine 1 di 1
    • Gently pull the keyboard up with your fingers. Do not pull the keyboard too far from the computer.
  4. HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, immagine 1 di 3 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, immagine 2 di 3 HP Pavilion TouchSmart 14z-n100  Keyboard Replacement: passo 4, immagine 3 di 3
    • Lift the plastic retaining tab with a small plastic opening tool. The tab will rotate to the side but not remove from the laptop. After this gently pull the wire ribbon to remove it. The old keyboard is now completely removed.
Conclusione
Antonio DiMattia
Membro da: 08/28/18
133 Reputazione
1 Guida realizzata
IUPUI, Team S1-G4, Arle Fall 2018 Membro di IUPUI, Team S1-G4, Arle Fall 2018
IUPUI-ARLE-F18S1G4
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 156
