Salta al contenuto principale
HP Pavilion Sleekbook 15-b000 RAM replacement
Cosa ti serve
  1. HP Pavilion Sleekbook 15-b000 RAM replacement, Battery: passo 1, immagine 1 di 1
    • Unplug laptop from adapter and all other devices.
  2. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 2, immagine 1 di 1
    • Flip the laptop over with battery facing you.
  3. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 3, immagine 1 di 2 HP Pavilion Sleekbook 15-b000 RAM replacement: passo 3, immagine 2 di 2
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 4, immagine 1 di 1
    • Pull battery out.
  5. HP Pavilion Sleekbook 15-b000 RAM replacement, Keyboard: passo 5, immagine 1 di 1
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 6, immagine 1 di 1
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 7, immagine 1 di 1
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 8, immagine 1 di 1
    • Remove keyboard wire by popping latch under blue plastic
  9. HP Pavilion Sleekbook 15-b000 RAM replacement, Case: passo 9, immagine 1 di 1
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 10, immagine 1 di 1
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 11, immagine 1 di 1
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 12, immagine 1 di 3 HP Pavilion Sleekbook 15-b000 RAM replacement: passo 12, immagine 2 di 3 HP Pavilion Sleekbook 15-b000 RAM replacement: passo 12, immagine 3 di 3
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. HP Pavilion Sleekbook 15-b000 RAM replacement, Motherboard: passo 13, immagine 1 di 2 HP Pavilion Sleekbook 15-b000 RAM replacement, Motherboard: passo 13, immagine 2 di 2
    • Disconnect motherboard cable from left side USB and jacks
  14. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 14, immagine 1 di 1
    • Remove the six 5.5mm Phillips #1 motherboard screws
    • Remove the one 3.5mm Phillips #1 screw from the WiFi chip
  15. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 15, immagine 1 di 1
    • Remove motherboard.
  16. HP Pavilion Sleekbook 15-b000 RAM replacement, RAM: passo 16, immagine 1 di 1
    • With the mother board removed flip it upside down.
  17. HP Pavilion Sleekbook 15-b000 RAM replacement: passo 17, immagine 1 di 1
    • Pull the clips attaching the ram outwards.
    • Remove ram at a angle.
    • Do not force the RAM loose, this can break the RAM or motherboard
Conclusione
Altre 2 persone hanno completato questa guida.
Sam Barkley
Membro da: 02/13/18
983 Reputazione
8 Guide realizzate
USF Tampa, Team S11-G2, Cheng Spring 2018 Membro di USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 337
