Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
The keyboard is one of the main components needed to interact with your laptop. This guide will show you how to replace your keyboard if you are having issues with typing on your laptop or to remove the keyboard for any further repairs to your laptop.
Parti
Nessuna parte specificata.
  1. Unplug laptop  from adapter and all other devices.
    • Unplug laptop from adapter and all other devices.
  2. Flip the laptop over with battery facing you.
    • Flip the laptop over with battery facing you.
  3. Slide the battery lock on the right side open. Slide the Battery release latch on the left side.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  5. Pull battery out.
    • Pull battery out.
  6. Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  7. Push screwdriver through screw hole top  pop the keyboard.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  8. Pry up the keyboard.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  9. Remove keyboard  wire  by popping latch under blue  plastic
    • Remove keyboard wire by popping latch under blue plastic
Conclusione
Sam Barkley
Membro da: 13/02/2018
959 Reputazione
8 Guide realizzate
USF Tampa, Team S11-G2, Cheng Spring 2018 Membro di USF Tampa, Team S11-G2, Cheng Spring 2018
USFT-CHENG-S18S11G2
4 Membri
10 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 107
