Salta al contenuto principale
HP Pavilion Sleekbook 14-b013cl Screen Replacement
Cosa ti serve
  1. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 2, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 2, immagine 2 di 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 3, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 3, immagine 2 di 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: passo 4, immagine 3 di 3
    • Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
    • Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
  5. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 5, immagine 3 di 3
    • Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
    • Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
    • Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
  6. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 6, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 6, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
    • Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
  7. HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 7, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: passo 7, immagine 2 di 2
    • Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
    • Remove the screen from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 491
