Salta al contenuto principale
HP Pavilion Sleekbook 14-b013cl Keyboard Replacement
Cosa ti serve
  1. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 2, immagine 2 di 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 3, immagine 2 di 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement, Keyboard: passo 4, immagine 1 di 1
    • Using the Phillips #0 screwdriver, remove the two screws.
  5. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 5, immagine 3 di 3
    • Use a plastic opening tool to pry up one of the upper counters on the keyboard
    • Run the tool along the upper edge of the keyboard and towards the opposite corner to release the latches.
  6. HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Keyboard Replacement: passo 6, immagine 3 di 3
    • Push the button to release the connector and pull it out and remove the keyboard
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 513
