Salta al contenuto principale
HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement
Cosa ti serve
  1. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 2, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 2, immagine 2 di 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 3, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement, Cooling Fan: passo 4, immagine 1 di 1
    • Using a Phillips #0 screwdriver, unscrew all nine of the screws from the bottom of the computer.
    • There is a wire connecting the keyboard to the motherboard. Do not pull the keyboard away until you have disconnected the wire.
  5. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 5, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 5, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 5, immagine 3 di 3
    • Using a plastic opening tool, pry up along the edge of the keyboard.
    • There is a wire connecting the keyboard to the motherboard. Do not completely pull the keyboard off until the wire is disconnected.
  6. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 6, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 6, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 6, immagine 3 di 3
    • To disconnect the wire, pry up on the latch connecting it to the motherboard.
  7. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 7, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 7, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 7, immagine 3 di 3
    • Using a plastic or metal spudger, carefully pry apart the palm rest from the rest of the laptop.
    • Be careful when using the metal spudger, as you could damage the internal components if the spudger is inserted too far.
    • Do not completely pull the halves apart yet because there are still wires holding them together.
  8. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 8, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 8, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 8, immagine 3 di 3
    • Disconnect the touch pad wire by flipping the black lever with a plastic spudger.
  9. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 9, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 9, immagine 2 di 2
    • Unscrew the circuit board underneath the power button.
    • Remove this circuit board by pulling up and away on the plastic tab.
  10. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 10, immagine 1 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 10, immagine 2 di 3 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 10, immagine 3 di 3
    • Using a Phillips #0 screwdriver, remove all the screws and take the metal plate off the mother board.
    • Double sided tape holds the plate down as well as the screws. You will need to apply force to remove the plate.
  11. HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 11, immagine 1 di 2 HP Pavilion Sleekbook 14-b013cl Cooling Fan Replacement: passo 11, immagine 2 di 2
    • Remove the three screws holding the cooling fan in place using a Phillips #0 screwdriver.
    • Using a plastic opening tool, remove the power cable for the fan.
    • Remove the fan from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 366
