Salta al contenuto principale
HP Pavilion Notebook 15-ab293cl Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Flip the laptop over so that the battery is facing upward.
  2. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 2, immagine 1 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 2, immagine 2 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide both tab buttons inward to open the battery cover. Gently push the battery out to remove.
  3. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 3, immagine 2 di 2
    • Remove the black plastic hinge covers at the top corners of the laptop.
    • Use the Phillips #1 to remove the two 7.5mm screws.
    • Use the opening tool to pry the black covers off of the laptop.
  4. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 4, immagine 1 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 4, immagine 2 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 4, immagine 3 di 3
    • Remember to remove the tabs shown in the second picture.
    • Remove all 16 - 7.5mm screws with the Phillips #1 screwdriver.
    • Pry and slide the CD/DVD drive out of the laptop case.
  5. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 5, immagine 1 di 1
    • Unscrew the two 3.5mm silver screws with the Phillips #000 and the Philips # 1.
  6. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 6, immagine 3 di 3
    • Turn the computer so that the screen faces you.
    • Use the pry tool to pry off the edge of the keyboard side of laptop.
  7. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 7, immagine 1 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 7, immagine 2 di 3 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 7, immagine 3 di 3
    • The hard drive is located in the bottom corner of the laptop.
    • Gently lift up the hard drive and pry off the white tab to release the hard drive.
  8. HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 8, immagine 1 di 2 HP Pavilion Notebook 15-ab293cl Hard Drive Replacement: passo 8, immagine 2 di 2
    • Once you release the white tab from the green board, remove the hard drive.
Conclusione
Efren Solis
Membro da: 09/10/18
228 Reputazione
1 Guida realizzata
Gateway, Team S1-G2, Luster Fall 2018 Membro di Gateway, Team S1-G2, Luster Fall 2018
GCC-LUSTER-F18S1G2
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 42
Tutti i Tempi: 2,739
