Salta al contenuto principale
HP Pavilion N3350 Keyboard Replacement
Cosa ti serve
  1. HP Pavilion N3350 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 HP Pavilion N3350 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Keyboard Replacement: passo 2, immagine 1 di 2 HP Pavilion N3350 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Keyboard Replacement: passo 3, immagine 1 di 2 HP Pavilion N3350 Keyboard Replacement: passo 3, immagine 2 di 2
    • Disconnect the green ribbon cable using a plastic opening tool.
Conclusione
Emily Hatstat
Membro da: 03/19/18
481 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 148
