Salta al contenuto principale
HP Pavilion N3350 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion N3350 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the laptop over and locate the grey finger latch.
  2. HP Pavilion N3350 Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the finger latch to the left to release the clip holding the battery into the laptop.
  3. HP Pavilion N3350 Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion N3350 Hard Drive Replacement: passo 3, immagine 2 di 2
    • While continuing to hold the finger latch, slowly lift up on the tab to remove the battery from the device.
  4. HP Pavilion N3350 Hard Drive Replacement, Hard Drive: passo 4, immagine 1 di 1
    • To unlock the hard drive, use a spudger to slide the button aside.
  5. HP Pavilion N3350 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Once the button is unlocked to the side, slide the hard drive enclosure away from the device.
  6. HP Pavilion N3350 Hard Drive Replacement: passo 6, immagine 1 di 1
    • The hard drive will be clipped into the underside of the hard drive enclosure and can be removed for replacement.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 204
