Salta al contenuto principale
HP Pavilion N3350 Fan Replacement
Cosa ti serve
  1. HP Pavilion N3350 Fan Replacement, Fan: passo 1, immagine 1 di 1
    • Locate the fan on the underside of the laptop.
  2. HP Pavilion N3350 Fan Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #1 screwdriver, remove the 4.5 mm screw securing the fan cover to the device.
  3. HP Pavilion N3350 Fan Replacement: passo 3, immagine 1 di 1
    • Use a plastic spudger tool to free the cover.
    • The fan cover is extremely fragile and easy to break. Use caution during this step.
  4. HP Pavilion N3350 Fan Replacement: passo 4, immagine 1 di 3 HP Pavilion N3350 Fan Replacement: passo 4, immagine 2 di 3 HP Pavilion N3350 Fan Replacement: passo 4, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Lift the fan up from the device.
    • If you're cleaning the fan, stop at this step, and remove any build up. This can be done with tweezers and canned air.
    • Disconnect the fan cable to fully remove the fan from the device.
Conclusione
Emily Hatstat
Membro da: 03/19/18
481 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 140
