Salta al contenuto principale
HP Pavilion G7-2289wm RAM Replacement
Cosa ti serve
  1. HP Pavilion G7-2289wm RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm RAM Replacement, RAM: passo 2, immagine 1 di 1
    • Loosen the screw that secures the service cover.
    • Pull the service cover towards you to remove it.
  3. HP Pavilion G7-2289wm RAM Replacement: passo 3, immagine 1 di 1
    • Unlock the tabs on each side of the ram module. (this lifts the ram module up)
  4. HP Pavilion G7-2289wm RAM Replacement: passo 4, immagine 1 di 1
    • Remove the ram module by pulling it gently away from the slot.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 124
