Salta al contenuto principale
HP Pavilion G7-2289wm Optical Drive Replacement
Cosa ti serve
  1. HP Pavilion G7-2289wm Optical Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Lift the edge of the service cover up and forward until it’s at an angle to remove it.
  3. HP Pavilion G7-2289wm Optical Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion G7-2289wm Optical Drive Replacement: passo 3, immagine 2 di 2
    • Remove the screw that secures the optical drive to the laptop using a Phillips #0 screwdriver.
    • Slide the optical drive out of the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 8
Tutti i Tempi: 295
