Salta al contenuto principale
HP Pavilion G7-2289wm Keyboard Replacement
Cosa ti serve
  1. HP Pavilion G7-2289wm Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Keyboard Replacement, Keyboard: passo 2, immagine 1 di 1
    • Remove all the screw that secures the keyboard to the computer using a Phillips #0 screwdriver.
  3. HP Pavilion G7-2289wm Keyboard Replacement: passo 3, immagine 1 di 3 HP Pavilion G7-2289wm Keyboard Replacement: passo 3, immagine 2 di 3 HP Pavilion G7-2289wm Keyboard Replacement: passo 3, immagine 3 di 3
    • Flip your laptop around to the front, using an opening tool, pry around the perimeter of the keyboard.
    • Lift the keyboard from the top backward towards the touch pad.
    • Unlatch the keyboard connector from the motherboard and remove the keyboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 207
