Salta al contenuto principale
HP Pavilion G7-2289wm Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion G7-2289wm Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Located on the bottom side of your laptop, slide the battery release latch to the left, towards the center of the laptop.
    • Lift the battery up, and pull towards the center of the laptop to remove it.
  2. HP Pavilion G7-2289wm Hard Drive Replacement, Hard Drive: passo 2, immagine 1 di 1
    • Loosen the screw that secures the service cover using a Phillips #0 screwdriver.
    • Pull the edge of the service cover toward you to remove it.
  3. HP Pavilion G7-2289wm Hard Drive Replacement: passo 3, immagine 1 di 1
    • Disconnect the hard drive connector cable from the motherboard.
  4. HP Pavilion G7-2289wm Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift the front edge of the hard drive, then pull the hard drive out gently.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 208
