Salta al contenuto principale
HP Pavilion G7-2235DX Screen Replacement
Cosa ti serve
  1. HP Pavilion G7-2235DX Screen Replacement, Fan: passo 1, immagine 1 di 1
    • Flip the laptop over and remove six 7.25mm screws.
  2. HP Pavilion G7-2235DX Screen Replacement: passo 2, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 2, immagine 2 di 2
    • Using the plastic opening tool or spudger, separate the keyboard from the frame of the laptop.
    • Gently pull the keyboard away from the laptop, toward you, until it is completely separated from the laptop.
  3. HP Pavilion G7-2235DX Screen Replacement: passo 3, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 3, immagine 2 di 2
    • Remove the four 7.25mm screws located by the red markers.
  4. HP Pavilion G7-2235DX Screen Replacement: passo 4, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 4, immagine 2 di 2
    • Gently lift the panel up, exposing the inside of the laptop.
  5. HP Pavilion G7-2235DX Screen Replacement: passo 5, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 5, immagine 2 di 2
    • The fan is located in the top, left hand corner. Now, it can be gently lifted out using your hands.
  6. HP Pavilion G7-2235DX Screen Replacement, Screen: passo 6, immagine 1 di 1
    • To remove the laptop's screen, you will have to remove a total of four 7.25mm screws.
    • First, remove the two 7.25mm screws found in the upper right corner as shown.
  7. HP Pavilion G7-2235DX Screen Replacement: passo 7, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 7, immagine 2 di 2
    • Next, unscrew the two 7.25mm screws in the upper left corner of the laptop as shown.
  8. HP Pavilion G7-2235DX Screen Replacement: passo 8, immagine 1 di 2 HP Pavilion G7-2235DX Screen Replacement: passo 8, immagine 2 di 2
    • Once all of the screws have been removed, gently lift the laptop's screen from the base of the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team 1-7, Leahy Fall 2016 Membro di USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 480
