Salta al contenuto principale
HP Pavilion G7-2235DX RAM Replacement
Cosa ti serve
  1. HP Pavilion G7-2235DX RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Before beginning, make sure the laptop is properly shut down and charger is detached.
    • Slide the battery release switch to the center of the computer to release the battery.
  2. HP Pavilion G7-2235DX RAM Replacement: passo 2, immagine 1 di 1
    • Remove the battery.
  3. HP Pavilion G7-2235DX RAM Replacement, RAM: passo 3, immagine 1 di 2 HP Pavilion G7-2235DX RAM Replacement, RAM: passo 3, immagine 2 di 2
    • Loosen the 7.25mm screw on the bottom of the laptop holding the "L" shaped cover down.
  4. HP Pavilion G7-2235DX RAM Replacement: passo 4, immagine 1 di 2 HP Pavilion G7-2235DX RAM Replacement: passo 4, immagine 2 di 2
    • Slide the cover towards you, then pull up to remove it.
  5. HP Pavilion G7-2235DX RAM Replacement: passo 5, immagine 1 di 2 HP Pavilion G7-2235DX RAM Replacement: passo 5, immagine 2 di 2
    • Locate the RAM card and the two prongs holding it in place.
  6. HP Pavilion G7-2235DX RAM Replacement: passo 6, immagine 1 di 1
    • Using either your fingers or two metal tools, push outwards on the two prongs until the RAM card pops out.
  7. HP Pavilion G7-2235DX RAM Replacement: passo 7, immagine 1 di 1
    • The RAM card can now be pulled out at a slight angle.
Conclusione
USF Tampa, Team 1-7, Leahy Fall 2016 Membro di USF Tampa, Team 1-7, Leahy Fall 2016
USFT-LEAHY-F16S1G7
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 393
