Salta al contenuto principale
HP Pavilion G60-247CL Fan Replacement
Cosa ti serve
  1. HP Pavilion G60-247CL Fan Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement, Battery: passo 1, immagine 3 di 3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Fan Replacement, RAM: passo 2, immagine 1 di 1
    • Locate RAM access door on the bottom side of the laptop.
  3. HP Pavilion G60-247CL Fan Replacement: passo 3, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 3, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 3, immagine 3 di 3
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  4. HP Pavilion G60-247CL Fan Replacement: passo 4, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 4, immagine 2 di 2
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  5. HP Pavilion G60-247CL Fan Replacement: passo 5, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 5, immagine 2 di 2
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  6. HP Pavilion G60-247CL Fan Replacement: passo 6, immagine 1 di 1
    • Gently lift the RAM stick up and out of its seat.
  7. HP Pavilion G60-247CL Fan Replacement: passo 7, immagine 1 di 1
    • Repeat the previous two steps for the remaining stick of RAM.
  8. HP Pavilion G60-247CL Fan Replacement, Screen: passo 8, immagine 1 di 1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  9. HP Pavilion G60-247CL Fan Replacement: passo 9, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 9, immagine 2 di 2
    • Remove the seven Phillips #0 screws from the battery compartment.
  10. HP Pavilion G60-247CL Fan Replacement: passo 10, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 10, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 10, immagine 3 di 3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  11. HP Pavilion G60-247CL Fan Replacement: passo 11, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 11, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 11, immagine 3 di 3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  12. HP Pavilion G60-247CL Fan Replacement: passo 12, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 12, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 12, immagine 3 di 3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  13. HP Pavilion G60-247CL Fan Replacement: passo 13, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 13, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  14. HP Pavilion G60-247CL Fan Replacement: passo 14, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 14, immagine 2 di 2
    • Remove the black wire from the top right corner by gently pulling outward.
  15. HP Pavilion G60-247CL Fan Replacement: passo 15, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 15, immagine 2 di 2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  16. HP Pavilion G60-247CL Fan Replacement: passo 16, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 16, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 16, immagine 3 di 3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  17. HP Pavilion G60-247CL Fan Replacement: passo 17, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 17, immagine 2 di 2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  18. HP Pavilion G60-247CL Fan Replacement: passo 18, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 18, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 18, immagine 3 di 3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  19. HP Pavilion G60-247CL Fan Replacement: passo 19, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 19, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 19, immagine 3 di 3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  20. HP Pavilion G60-247CL Fan Replacement: passo 20, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 20, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 20, immagine 3 di 3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  21. HP Pavilion G60-247CL Fan Replacement: passo 21, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 21, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 21, immagine 3 di 3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  22. HP Pavilion G60-247CL Fan Replacement: passo 22, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 22, immagine 2 di 2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  23. HP Pavilion G60-247CL Fan Replacement: passo 23, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 23, immagine 2 di 2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  24. HP Pavilion G60-247CL Fan Replacement: passo 24, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 24, immagine 2 di 2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  25. HP Pavilion G60-247CL Fan Replacement: passo 25, immagine 1 di 1
    • Remove the screen from the outer casing carefully.
  26. HP Pavilion G60-247CL Fan Replacement, Speakers: passo 26, immagine 1 di 1
    • With the battery and RAM removed, locate the hard drive access panel.
  27. HP Pavilion G60-247CL Fan Replacement: passo 27, immagine 1 di 1
    • Remove two 1.2 mm Philips#01 screws.
  28. HP Pavilion G60-247CL Fan Replacement: passo 28, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 28, immagine 2 di 2
    • After the screws are removed, slide the hard drive panel to right to remove it.
  29. HP Pavilion G60-247CL Fan Replacement: passo 29, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 29, immagine 2 di 2
    • Identify the three screws holding the hard drives cover in place.
    • Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  30. HP Pavilion G60-247CL Fan Replacement: passo 30, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 30, immagine 2 di 2
    • Locate the storage battery, next to the hard drive.
    • Genlty pop out storage battery with fingers.
  31. HP Pavilion G60-247CL Fan Replacement: passo 31, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 31, immagine 2 di 2
    • Locate the Wifi card cover panel, left of the RAM.
    • Using a Philips #1 screwdriver remove the screw holding the panel down.
  32. HP Pavilion G60-247CL Fan Replacement: passo 32, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 32, immagine 2 di 2
    • Lift up on the screw side to remove the panel.
  33. HP Pavilion G60-247CL Fan Replacement: passo 33, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 33, immagine 2 di 2
    • As the screws are removed the Wifi card will pop up.
  34. HP Pavilion G60-247CL Fan Replacement: passo 34, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 34, immagine 2 di 2
    • Remove Wifi card by pulling to the left of the laptop.
  35. HP Pavilion G60-247CL Fan Replacement: passo 35, immagine 1 di 1
    • Flip over to the top view
    • Remove five 1.2 mm Philips#00 swrews
  36. HP Pavilion G60-247CL Fan Replacement: passo 36, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 36, immagine 2 di 2
    • Using a spudger unclip the casing around all corners and edges.
  37. HP Pavilion G60-247CL Fan Replacement: passo 37, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 37, immagine 2 di 2
    • lift up the casing and remove to reveal the speakers.
  38. HP Pavilion G60-247CL Fan Replacement: passo 38, immagine 1 di 1
    • Remove highlighted 1.2 mm Philips #00 screw from right speaker.
  39. HP Pavilion G60-247CL Fan Replacement: passo 39, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 39, immagine 2 di 2
    • Using a spudger, remove the highlighted white wire.
  40. HP Pavilion G60-247CL Fan Replacement: passo 40, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 40, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 40, immagine 3 di 3
    • Using a spudger, remove both additional highlighted wires from the motherboad.
  41. HP Pavilion G60-247CL Fan Replacement: passo 41, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 41, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 41, immagine 3 di 3
    • Lift up and out each speaker from the base.
  42. HP Pavilion G60-247CL Fan Replacement, Fan: passo 42, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement, Fan: passo 42, immagine 2 di 2
    • Locate the fan in the top left corner.
    • Carefully disconnect the wire attached to the motherboard using your fingers.
  43. HP Pavilion G60-247CL Fan Replacement: passo 43, immagine 1 di 1
    • Locate the disk player in the bottom right corner.
    • Remove three screws using a Phillips #00 screwdriver.
  44. HP Pavilion G60-247CL Fan Replacement: passo 44, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 44, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 44, immagine 3 di 3
    • Slide out the disk player to the right.
  45. HP Pavilion G60-247CL Fan Replacement: passo 45, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 45, immagine 2 di 2
    • Gently disconnect the ribbon cable using an opening tool.
  46. HP Pavilion G60-247CL Fan Replacement: passo 46, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 46, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 46, immagine 3 di 3
    • Disconnect the wire connected to motherboard by gently pulling downwards.
  47. HP Pavilion G60-247CL Fan Replacement: passo 47, immagine 1 di 3 HP Pavilion G60-247CL Fan Replacement: passo 47, immagine 2 di 3 HP Pavilion G60-247CL Fan Replacement: passo 47, immagine 3 di 3
    • Disconnect the wire connected to the motherboard using an opening tool.
  48. HP Pavilion G60-247CL Fan Replacement: passo 48, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 48, immagine 2 di 2
    • Gently remove motherboard with fan from the shell.
  49. HP Pavilion G60-247CL Fan Replacement: passo 49, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 49, immagine 2 di 2
    • Flip over the motherboard to view the back side.
    • Remove four 1.6 mm screws with a Phillips #1 screwdriver.
  50. HP Pavilion G60-247CL Fan Replacement: passo 50, immagine 1 di 2 HP Pavilion G60-247CL Fan Replacement: passo 50, immagine 2 di 2
    • Gently lift out the fan.
Conclusione
Haley Matthews
Membro da: 03/12/18
517 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 305
