Salta al contenuto principale
HP Pavilion G60-235DX Ram Replacement
Cosa ti serve
  1. HP Pavilion G60-235DX Ram Replacement, Ram: passo 1, immagine 1 di 1
    • Lay the computer so that the backside is facing you and locate the screw in the picture.
  2. HP Pavilion G60-235DX Ram Replacement: passo 2, immagine 1 di 1
    • Remove the screws.
  3. HP Pavilion G60-235DX Ram Replacement: passo 3, immagine 1 di 1
    • Remove the cover that was held in by the screws that you just removed.
  4. HP Pavilion G60-235DX Ram Replacement: passo 4, immagine 1 di 1
    • Push this slide over in order to remove the battery. This is safe when working with your computers memory.
  5. HP Pavilion G60-235DX Ram Replacement: passo 5, immagine 1 di 1
    • Remove each one of the rams so that the computer looks like this. You can do so be squeezing tabs on each side of the ram.
Conclusione
James de Fremery
Membro da: 01/26/17
201 Reputazione
2 Guide realizzate
Cal Poly, Team 10-5, Banghart Winter 2017 Membro di Cal Poly, Team 10-5, Banghart Winter 2017
CPSU-BANGHART-W17S10G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 183
