Salta al contenuto principale
HP Pavilion G6-1d16dx Screen hinges Replacement
Cosa ti serve
  1. HP Pavilion G6-1d16dx Screen hinges Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 2, immagine 1 di 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 3, immagine 1 di 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Screen hinges Replacement, Motherboard: passo 4, immagine 1 di 1
    • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
    • The screws do not remove from the cover.
  5. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 5, immagine 1 di 2 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 5, immagine 2 di 2
    • Unsnap the Cover by lifting the edge along the battery compartment.
    • Remove all of the body screws.
    • Remove the rubber cap and the screw underneath it.
    There are 10 body screws plus one that holds the hard disk cover!
    Eveline Bernard - Replica
    “Remove the rubber cap and the screw underneath it.”
    I assume you mean the rubber feet at the four corners? Which of the rubber feet hides that screw?
    There are body screws under the protective hard - disk - and - memory - cover! That cover has to be removed first!
    Remove the hard disk (described much to late in step 11).
    There are 2 screws under the hard disk.
    The memory can stay in place.
  6. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 6, immagine 1 di 3 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 6, immagine 2 di 3 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 6, immagine 3 di 3
    • The keyboard is held in by nine tabs
    • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
    A plastic card (credit card or the like) is handy to keep the keyboard up while opening the nine tabs.
    Make sure you did remove the screw that is at the under side between the memory compartment and the radio compartment!
    The screw that is at the underside between the memory compartment and the radio compartment is the one screw holding the keyboard in place, apart from the 9 tabs.
  7. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 7, immagine 1 di 2 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 7, immagine 2 di 2
    • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
    • As you depress the tabs, the edges of the keyboard will pop up.
    • Lift off the keyboard
  8. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 8, immagine 1 di 1
    • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
  9. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 9, immagine 1 di 3 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 9, immagine 2 di 3 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 9, immagine 3 di 3
    • Remove the two remaining ribbon cables.
    • Remove the screws holding in the protective cover underneath the keyboard.
    • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
    • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
    “Remove the screws holding in the protective cover underneath the keyboard. “ there are 6 of them, see image
    “Pop the cover off using any flat metal tool, starting with where you took out the optical drive “
    When did we remove the optical drive? How?
    “Remove the screws holding in the protective cover underneath the keyboard.” There is only one screw holding the cover protecting the hard disk and memory.
  10. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 10, immagine 1 di 1
    • Unplug the ribbon cable on the right side of the motherboard.
    Before removing the top, the dolby speaker units and their cable of have to be freed!
  11. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 11, immagine 1 di 2 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 11, immagine 2 di 2
    • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
  12. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 12, immagine 1 di 1
    • Unscrew all mother board screws and lift the motherboard out of the body.
    • For replacing the screen hinges and screen, skip this step
    For replacing the screen hinges, disregard this step.
    Calvin Kerr - Replica
  13. HP Pavilion G6-1d16dx Screen hinges Replacement, Screen hinges: passo 13, immagine 1 di 1
    • Remove the five screws holding hinges to base.
    • Do not unscrew the motherboard screws
  14. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 14, immagine 1 di 2 HP Pavilion G6-1d16dx Screen hinges Replacement: passo 14, immagine 2 di 2
    • Lift the tape tab up from the screen plug, and unplug the screen from the motherboard.
    • Unplug the wires from the wireless card and pull them through the body.
  15. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 15, immagine 1 di 1
    • Remove the sticky tabs on the bottom of the screen just outside the hinges, and remove the two screws underneath.
  16. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 16, immagine 1 di 1
    • Pry off the plastic surrounding the screen with any flat metal tool.
    Then after what can I do
    Md Riyaz Ansari - Replica
  17. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 17, immagine 1 di 1
    • Remove the screws holding the hinge covers in place.
    • Remove the hinge covers.
  18. HP Pavilion G6-1d16dx Screen hinges Replacement: passo 18, immagine 1 di 1
    • Use a pair of pliers to unscrew the nut and pull out the hinge.
    When the issue with the hinge is: ‘it hardly moves’ it is also very hard to pull the hinge halves apart. Maybe you need to apply a solvent.
    This laptop is of extremely poor building quality. Disaster lures in every badly made detail.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Not so good a manual. See my remarks.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 3,401
