Salta al contenuto principale
HP Pavilion DV9700 RAM Replacement
Cosa ti serve
  1. HP Pavilion DV9700 RAM Replacement, RAM: passo 1, immagine 1 di 2 HP Pavilion DV9700 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Turn the device over so that the bottom is facing upward.
    • Locate the three panels near the bottom half of the device.
    • The middle-most panel is the one we will be focusing on.
    • Using a Philips #0 screwdriver, unscrew the two 4mm screws that hold this panel in place.
  2. HP Pavilion DV9700 RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion DV9700 RAM Replacement: passo 2, immagine 2 di 2
    • Pull the bottom of the panel upward.
    • Then pull the panel toward yourself to remove.
  3. HP Pavilion DV9700 RAM Replacement: passo 3, immagine 1 di 3 HP Pavilion DV9700 RAM Replacement: passo 3, immagine 2 di 3 HP Pavilion DV9700 RAM Replacement: passo 3, immagine 3 di 3
    • Look toward the top half of the exposed compartment.
    • Each ram stick will have two silver clips on the left and right side.
    • Push these clips outward at the same time to release the ram stick.
  4. HP Pavilion DV9700 RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion DV9700 RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion DV9700 RAM Replacement: passo 4, immagine 3 di 3
    • The ram stick will be held at a 45 degree angle. Pull the stick upward to release it from the slot.
    • Each ram stick will have a notch near the bottom, make sure to keep note of which side this notch is on.
    • Make sure to place the ram away from any static surfaces (carpet, fabric, etc.)
Conclusione
Max Shangraw
Membro da: 03/19/18
507 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 737
