Salta al contenuto principale
Introduzione
If your are experiencing problems with your device's Optical Drive consult this repair guide to restore your device to working order. Problems can include disks not loading, noisy disk drive, and scratching of inserted disks. To Start this guide all you need is a Phillip's head screwdriver.
Parti
Nessuna parte specificata.
  1. Turn the device over so that the bottom is facing upward. Find the screw with an imprint of a disk underneath it. It is located near the center of the device. Remove this 6mm screw with a Philips #0 screwdriver.
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  3. The optical drive is located toward the left side of the device. Using a spudger, pry the optical drive away from the casing. Pull the rest of the optical drive out with your hand.
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Conclusione
Max Shangraw
Membro da: 19/03/2018
495 Reputazione
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 67
