Salta al contenuto principale
HP Pavilion DV3 RAM Replacement
Cosa ti serve
  1. HP Pavilion DV3 RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion DV3 RAM Replacement: passo 2, immagine 2 di 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 RAM Replacement, RAM: passo 3, immagine 1 di 3 HP Pavilion DV3 RAM Replacement, RAM: passo 3, immagine 2 di 3 HP Pavilion DV3 RAM Replacement, RAM: passo 3, immagine 3 di 3
    • Remove the two 3.5 mm diameter head and 7 mm long screws using the Philips PH1 screwdriver.
    • Both screws will remain attached to the cover.
    • Set the cover with attached screws to the side.
    • The RAM will now be exposed
  4. HP Pavilion DV3 RAM Replacement: passo 4, immagine 1 di 3 HP Pavilion DV3 RAM Replacement: passo 4, immagine 2 di 3 HP Pavilion DV3 RAM Replacement: passo 4, immagine 3 di 3
    • Find the two clips located on each side of the RAM.
    • Using both hands, simultaneously grab each clip and open them away from the RAM stick.
    • The RAM will pop up.
  5. HP Pavilion DV3 RAM Replacement: passo 5, immagine 1 di 2 HP Pavilion DV3 RAM Replacement: passo 5, immagine 2 di 2
    • Using one hand, pull the RAM up and to the left to remove it.
  6. HP Pavilion DV3 RAM Replacement: passo 6, immagine 1 di 1
    • If there is a second RAM module present (as shown), repeat steps 2 and 3 to remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 14-10, Forte Fall 2013 Membro di Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,977
