Salta al contenuto principale
HP Pavilion DV3 HP Pavilion Wireless Card Replacement
Cosa ti serve
  1. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Battery: passo 1, immagine 1 di 1
    • Step 1 – Battery: Locate the battery release slider on the bottom of the laptop and move it in the direction of the arrow to the unlock position.
    • The yellow highlighted edge of the battery should pop up slightly when the switch is moved
  2. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 2, immagine 1 di 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 2, immagine 2 di 2
    • Step 2: Using the edge of the battery that has popped up, lift the battery out of the computer.
  3. HP Pavilion DV3 HP Pavilion Wireless Card Replacement, Wireless Card: passo 3, immagine 1 di 1
    • With the laptop upside down, locate the three screws on the wireless card cover and unscrew the screws.
    • All three screws will have a 3.5 mm diameter head.
    • Two of the screws will be silver, 7mm in length, and will stay attached to the cover.
    • One screw will be black, 13mm in length, and will separate from the cover. Set this screw aside.
  4. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 4, immagine 1 di 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 4, immagine 2 di 2
    • Grab one of the edges to the cover and lift up (towards you).
    • Set the cover to the side.
    • The wireless card will now be exposed.
  5. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, immagine 1 di 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, immagine 2 di 3 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 5, immagine 3 di 3
    • Using your hand, pull the black and white antenna wires upwards.
    • This will disconnect the antenna wires from the card.
  6. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 6, immagine 1 di 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 6, immagine 2 di 2
    • Locate the two black screws connecting the wireless card to the laptop. They will have a 3.5 mm diameter head and be 4mm long. Remove the screws.
    • Once the screws are removed, the wireless card will pop up.
  7. HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 7, immagine 1 di 2 HP Pavilion DV3 HP Pavilion Wireless Card Replacement: passo 7, immagine 2 di 2
    • Grab the sides of the wireless card and pull it up and to the left to disconnect from the laptop.
Conclusione
Cal Poly, Team 14-10, Forte Fall 2013 Membro di Cal Poly, Team 14-10, Forte Fall 2013
CPSU-FORTE-F13S14G10
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,612
