Salta al contenuto principale
HP Pavilion DV2160BR Wifi Adapter Replacement
Cosa ti serve
  1. HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: passo 1, immagine 1 di 2 HP Pavilion DV2160BR Wifi Adapter Replacement, Wifi Adapter: passo 1, immagine 2 di 2
    • Start with the bottom of the laptop facing up.
    • Locate the small panel under the battery, which houses the wifi adapter, and unscrew the one 5mm Phillips #0 screw holding the panel in place.
    • Remove the panel and set it aside.
    • Be careful not to snap the 2 tabs on the sides of the panel when pulling it out.
  2. HP Pavilion DV2160BR Wifi Adapter Replacement: passo 2, immagine 1 di 2 HP Pavilion DV2160BR Wifi Adapter Replacement: passo 2, immagine 2 di 2
    • Unscrew the two 3mm Phillips #0 screw which is located at the corners of the wifi adapter.
  3. HP Pavilion DV2160BR Wifi Adapter Replacement: passo 3, immagine 1 di 2 HP Pavilion DV2160BR Wifi Adapter Replacement: passo 3, immagine 2 di 2
    • Pull the 2 black wires with the gold pieces out of the wifi adapter.
    • The wifi adapter is now free to be removed.
    • When reconnecting the wires for re-installing the wifi adapter, make sure the gold ends are rotated correctly to be properly pushed back in.
Conclusione
Shannon
Membro da: 04/11/13
55 Reputazione
6 Guide realizzate
Cal Poly, Team 13-66, Johann Spring 2013 Membro di Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 533
