Salta al contenuto principale
HP Pavilion DV2160BR Webcam Replacement
Cosa ti serve
  1. HP Pavilion DV2160BR Webcam Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR Webcam Replacement: passo 2, immagine 1 di 2 HP Pavilion DV2160BR Webcam Replacement: passo 2, immagine 2 di 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR Webcam Replacement, Webcam: passo 3, immagine 1 di 1
    • Flip over the laptop and open it.
  4. HP Pavilion DV2160BR Webcam Replacement: passo 4, immagine 1 di 2 HP Pavilion DV2160BR Webcam Replacement: passo 4, immagine 2 di 2
    • Remove the 6 rubber screw covers from the screen panel using the plastic opener tools by applying firm pressure to the edges.
    • The 4 screw covers on top are attached by an adhesive backing.
    • The 2 screw covers on the bottom are rubber plugs.
  5. HP Pavilion DV2160BR Webcam Replacement: passo 5, immagine 1 di 1
    • Remove the 4 M2.5x4-Lg #0 Phillips screws from the top of the screen panel.
    • Remove the 2 M2.5x8-Lg #1 Phillips screws from the bottom of the screen panel.
  6. HP Pavilion DV2160BR Webcam Replacement: passo 6, immagine 1 di 2 HP Pavilion DV2160BR Webcam Replacement: passo 6, immagine 2 di 2
    • Slide a plastic opener tool along the outside edges of the front screen panel to start to separate it from the back screen panel.
    • You may need to apply some firm pressure to get it started.
    • Once it has started to separate, gently pull off the screen panel by working along the edge, and set it aside.
  7. HP Pavilion DV2160BR Webcam Replacement: passo 7, immagine 1 di 1
    • Locate the screw on the left side of the cameras mounting bracket.
    • Remove the M2.5x4-Lg #0 Phillips screw
  8. HP Pavilion DV2160BR Webcam Replacement: passo 8, immagine 1 di 1
    • Pull the camera from the back screen panel and rotate it so you are looking at the back.
    • Remove the 2 M2x3-Lg #00 Phillips screws and place the mounting bracket aside.
  9. HP Pavilion DV2160BR Webcam Replacement: passo 9, immagine 1 di 1
    • Disconnect the cable on the right side of the camera board by pulling firmly on the connector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 789
