Salta al contenuto principale
HP Pavilion DV2160BR RAM Replacement
Cosa ti serve
  1. HP Pavilion DV2160BR RAM Replacement, RAM: passo 1, immagine 1 di 2 HP Pavilion DV2160BR RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel that is covering the RAM compartment.
    • Unscrew the two 5mm Phillips #0 screws that are securing the RAM compartment.
  2. HP Pavilion DV2160BR RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion DV2160BR RAM Replacement: passo 2, immagine 2 di 2
    • Lift up the panel that is by the end that held the screws. Set it aside.
  3. HP Pavilion DV2160BR RAM Replacement: passo 3, immagine 1 di 3 HP Pavilion DV2160BR RAM Replacement: passo 3, immagine 2 di 3 HP Pavilion DV2160BR RAM Replacement: passo 3, immagine 3 di 3
    • Using 2 prying tools, push the 2 buttons on the sides of one RAM module simultaneously, so that one side of the module pops up and out of the clips holding it down.
    • Grab the RAM module and carefully pull it straight out of its slot.
    • Repeat this step for the second RAM module, which is located just underneath the first RAM module.
Conclusione
Shannon
Membro da: 04/11/13
55 Reputazione
6 Guide realizzate
Cal Poly, Team 13-66, Johann Spring 2013 Membro di Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 380
