Salta al contenuto principale
HP Pavilion DV2160BR Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion DV2160BR Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Start with the bottom of the laptop facing up.
    • Locate the panel covering the hard drive compartment.
    • Unscrew the two 5mm Phillips #0 screws.
  2. HP Pavilion DV2160BR Hard Drive Replacement: passo 2, immagine 1 di 1
    • Lift up this external panel by the end with the screws and set it aside.
    • Be careful about the four plastic tabs holding the panel on the device.
  3. HP Pavilion DV2160BR Hard Drive Replacement: passo 3, immagine 1 di 2 HP Pavilion DV2160BR Hard Drive Replacement: passo 3, immagine 2 di 2
    • Locate the second plastic panel covering the hard drive.
    • Unscrew the two 4mm Phillips #0 screws holding it in.
  4. HP Pavilion DV2160BR Hard Drive Replacement: passo 4, immagine 1 di 1
    • Lift up this internal panel using the plastic white tab and set it aside.
  5. HP Pavilion DV2160BR Hard Drive Replacement: passo 5, immagine 1 di 3 HP Pavilion DV2160BR Hard Drive Replacement: passo 5, immagine 2 di 3 HP Pavilion DV2160BR Hard Drive Replacement: passo 5, immagine 3 di 3
    • Grab the end of the hard drive and pull it up to a vertical position.
    • Gently slide the Hard Drive off of the SATA connector.
    • Warning: Don’t wiggle the SATA connector or the top piece will come off. If it does, reconnect it vertically.
Conclusione
Shannon
Membro da: 04/11/13
55 Reputazione
6 Guide realizzate
Cal Poly, Team 13-66, Johann Spring 2013 Membro di Cal Poly, Team 13-66, Johann Spring 2013
CPSU-JOHANN-S13S13G66
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 535
