Salta al contenuto principale
HP Pavilion DV2160BR DVD±RW Drive Replacement
Cosa ti serve
  1. HP Pavilion DV2160BR DVD±RW Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Start with the bottom of the laptop facing up.
  2. HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 2, immagine 2 di 2
    • Locate the battery compartment at the rear of the device.
    • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
  3. HP Pavilion DV2160BR DVD±RW Drive Replacement, DVD±RW Drive: passo 3, immagine 1 di 1
    • Locate the locking screw which is located in a recessed hole on the underside of the laptop.
    • Remove the M2.5X3-Lg #1 Phillips screw.
  4. HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 4, immagine 2 di 2
    • Locate the CD drive tray release hole on the front of the drive.
    • Straighten a paper clip and push it gently into the CD drive tray release hole.
    • The drive tray will pop open.
  5. HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 5, immagine 1 di 1
    • Grasp the side edges of the drive tray.
    • Gently pull the drive from the laptop.
  6. HP Pavilion DV2160BR DVD±RW Drive Replacement: passo 6, immagine 1 di 1
    • Locate the mounting bracket which is attached to the back of the drive.
    • Remove the two M2x3-Lg #0 Phillips screws.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 239
