Salta al contenuto principale
HP Pavilion DM4 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion DM4 Hard Drive  Replacement, Hard drive: passo 1, immagine 1 di 2 HP Pavilion DM4 Hard Drive  Replacement, Hard drive: passo 1, immagine 2 di 2
    • Unlock and remove the battery pack.
  2. HP Pavilion DM4 Hard Drive  Replacement: passo 2, immagine 1 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 2, immagine 2 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 2, immagine 3 di 3
    • Unscrew the hidden screws covered by the battery pack and remove the panel to find more hidden screws.
  3. HP Pavilion DM4 Hard Drive  Replacement: passo 3, immagine 1 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 3, immagine 2 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 3, immagine 3 di 3
    • Unscrew the hidden screws in order to remove the hard drive cover.
  4. HP Pavilion DM4 Hard Drive  Replacement: passo 4, immagine 1 di 1
    • Pull out the tab to remove the hard drive.
  5. HP Pavilion DM4 Hard Drive  Replacement: passo 5, immagine 1 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 5, immagine 2 di 3 HP Pavilion DM4 Hard Drive  Replacement: passo 5, immagine 3 di 3
    • Take the hard drive out and pull the connector from it.
    • In order to disconnect the hard drive, grab the hard drive and cord then gently pull the hard drive away from the cord.
  6. HP Pavilion DM4 Hard Drive  Replacement: passo 6, immagine 1 di 1
    • Replace the hard drive.
    • Do not take apart the hard drive if you want it to run anything at all!
Conclusione
Altre 8 persone hanno completato questa guida.
Un commento
I need to replace the hard drive and was wondering how large can the DM4 handle. It is currently 578Gb and it would be great for 1 or 2 TB. Thanks
epascual1960 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 7,883
