Salta al contenuto principale
HP Pavilion DM3-3010US Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion DM3-3010US Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Flip laptop over to back with the battery facing downwards.
    • The battery is the silver cylinder located on the bottom of the laptop.
  2. HP Pavilion DM3-3010US Hard Drive Replacement: passo 2, immagine 1 di 1
    • Locate switch for battery ejection.
    • Battery ejection switch is located just above the left side of the battery.
  3. HP Pavilion DM3-3010US Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove battery by sliding the battery ejection switch to the right and pulling the battery away from the laptop.
  4. HP Pavilion DM3-3010US Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion DM3-3010US Hard Drive Replacement: passo 4, immagine 2 di 2
    • Using a plastic opening tool, remove the large square casing located on the bottom right side of the laptop.
    • The hard drive will be visible once the casing has been removed.
  5. HP Pavilion DM3-3010US Hard Drive Replacement: passo 5, immagine 1 di 2 HP Pavilion DM3-3010US Hard Drive Replacement: passo 5, immagine 2 di 2
    • Using a Phillips #0 Screwdriver, remove each of the six Phillips #0 screws.
    • Four screws are located on each corner of the hard-drive.
    • Two screws are located on the right side of the battery slot.
  6. HP Pavilion DM3-3010US Hard Drive Replacement: passo 6, immagine 1 di 1
    • Remove old hard drive from its slot and replace with new hard drive, sticker side facing up.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,863
