Salta al contenuto principale
HP Pavilion 500-259 Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 HP Pavilion 500-259 Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Power down and unplug all wires from the computer before proceeding.
    • Use a Phillips #1 screwdriver to remove the single 6 mm screw securing the side panel.
    • These screws can often be removed by hand.
  2. HP Pavilion 500-259 Hard Drive Replacement: passo 2, immagine 1 di 2 HP Pavilion 500-259 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Slide the front panel back and off the chassis.
  3. HP Pavilion 500-259 Hard Drive Replacement: passo 3, immagine 1 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 3, immagine 2 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 3, immagine 3 di 3
    • The hard drive is found on the left-hand side of the case.
  4. HP Pavilion 500-259 Hard Drive Replacement: passo 4, immagine 1 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 4, immagine 2 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Unplug the two cables attached to the back of the hard drive.
  5. HP Pavilion 500-259 Hard Drive Replacement: passo 5, immagine 1 di 1
    • Place one hand underneath the hard drive to prevent it from falling, then remove the two 2 mm screws attaching the hard drive to the case with a Phillips #2 screwdriver.
  6. HP Pavilion 500-259 Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion 500-259 Hard Drive Replacement: passo 6, immagine 3 di 3
    • Slide the hard drive out of the case.
Conclusione
Altre 6 persone hanno completato questa guida.
Farhan Khan
Membro da: 01/15/22
283 Reputazione
1 Guida realizzata
2 Commenti
Why does it look like that drive is mounted sideways with just two screws? The original 3.5" hard drive is mounted flat to the lower 3.5 in mounting Bay. I was looking for advice on how to mount the SSD to the upper 2.5 in mounting Bay. I have serious doubts about the instructions you've posted.
Dave Hill - Replica
Hello Dave, this particular HP Pavilion desktop had the hard-drive mounted sideways with two screws, the 2.5" hard-drive being as lightweight as it was able to be supported by just the two screws. I made this guide about a year ago and cannot remember if the hard-drive was able to be mounted flat with the given hole placements. However, I have linked a Youtube video down below that might provide some assistance when trying to mount your 2.5" hard drive despite the video showing a 3.5" drive.
HP Hard drive replacement video: https://www.youtube.com/watch?v=PxT_qPzl...
Thank you for taking the time to look at my guide and I hope this response provides at least a little assistance.
Farhan Khan -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 101
Tutti i Tempi: 2,857
