Salta al contenuto principale
HP Pavilion 17-x047na Hard Drive Replacement
Cosa ti serve
  1. HP Pavilion 17-x047na Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP Pavilion 17-x047na Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Turn off and unplug the laptop before replacing the battery.
    • The netbook needs to be top-side down with the lid closed.
    • Slide the plastic battery release latches towards the lock symbols.
  2. HP Pavilion 17-x047na Hard Drive Replacement: passo 2, immagine 1 di 1
    • Slide the battery out from the laptop.
  3. HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: passo 3, immagine 1 di 2 HP Pavilion 17-x047na Hard Drive Replacement, Back Panel: passo 3, immagine 2 di 2
    • Using a Phillips #0 screwdriver, remove thirteen 7.0 mm screws from the back case.
    • Using a Phillips #0 screwdriver, remove the CD/DVD drive screw.
    • Use an ejection pin to eject and remove the CD/DVD drive.
  4. HP Pavilion 17-x047na Hard Drive Replacement: passo 4, immagine 1 di 2 HP Pavilion 17-x047na Hard Drive Replacement: passo 4, immagine 2 di 2
    • Use an iFixit opening tool to separate the back cover from the laptop.
    • Gently pry open the cover, trying not to break the plastic.
  5. HP Pavilion 17-x047na Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 1
    • Locate the hard drive.
  6. HP Pavilion 17-x047na Hard Drive Replacement: passo 6, immagine 1 di 3 HP Pavilion 17-x047na Hard Drive Replacement: passo 6, immagine 2 di 3 HP Pavilion 17-x047na Hard Drive Replacement: passo 6, immagine 3 di 3
    • To remove the hard drive, lift both latches to remove the ribbon cable.
    • Once ribbon cable is removed, use the rubber case surrounding the hard drive to lift upwards and pull the hard drive out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 479
