Salta al contenuto principale
HP Pavilion 17-g192dx Screen Replacement
Cosa ti serve
  1. HP Pavilion 17-g192dx Screen Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion 17-g192dx Screen Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion 17-g192dx Screen Replacement, Battery: passo 1, immagine 3 di 3
    • Turn off the laptop.
    • Slide the battery lock to the right until you see the open lock symbol.
  2. HP Pavilion 17-g192dx Screen Replacement: passo 2, immagine 1 di 1
    • Slide the battery release to the left until the battery pops up.
    • This may require significant force.
  3. HP Pavilion 17-g192dx Screen Replacement: passo 3, immagine 1 di 2 HP Pavilion 17-g192dx Screen Replacement: passo 3, immagine 2 di 2
    • Lift the battery up.
  4. HP Pavilion 17-g192dx Screen Replacement, Screen: passo 4, immagine 1 di 2 HP Pavilion 17-g192dx Screen Replacement, Screen: passo 4, immagine 2 di 2
    • Using the metal spudger, remove the 2 plastic screw covers at the bottom corners of the screen.
  5. HP Pavilion 17-g192dx Screen Replacement: passo 5, immagine 1 di 1
    • Remove the two 7mm screws with a Philips #00 screwdriver.
  6. HP Pavilion 17-g192dx Screen Replacement: passo 6, immagine 1 di 3 HP Pavilion 17-g192dx Screen Replacement: passo 6, immagine 2 di 3 HP Pavilion 17-g192dx Screen Replacement: passo 6, immagine 3 di 3
    • Use a plastic opening tool to remove the plastic cover surrounding the screen by running the tool around the edge.
    • It may be helpful to start with the metal spudger then transition to the plastic opening tool because you will need the metal tip get in initially.
  7. HP Pavilion 17-g192dx Screen Replacement: passo 7, immagine 1 di 3 HP Pavilion 17-g192dx Screen Replacement: passo 7, immagine 2 di 3 HP Pavilion 17-g192dx Screen Replacement: passo 7, immagine 3 di 3
    • Remove the four 4 mm screws holding the back to the display assembly with a Philips #00 screwdriver.
    • Remove the two 3mm screws holding the back cover to the display assembly with a Philips #00 screwdriver.
    • Lay the cover on the workspace carefully as not to damage the wires still connected to it.
  8. HP Pavilion 17-g192dx Screen Replacement: passo 8, immagine 1 di 1
    • Unplug the wire connected to the display assembly by gently pulling on it.
    • Tape may be holding it in place.
  9. HP Pavilion 17-g192dx Screen Replacement: passo 9, immagine 1 di 2 HP Pavilion 17-g192dx Screen Replacement: passo 9, immagine 2 di 2
    • Remove the four 3mm screws connecting the display assembly to the metal framework with a Philips #00 screwdriver.
    • It may be helpful to have someone else support the screen while you remove it.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 350
