Salta al contenuto principale
HP Pavilion 17-g119dx RAM Replacement
Cosa ti serve
  1. HP Pavilion 17-g119dx RAM Replacement, Battery: passo 1, immagine 1 di 1
    • Close your laptop and turn it over so that the bottom is facing up.
  2. HP Pavilion 17-g119dx RAM Replacement: passo 2, immagine 1 di 2 HP Pavilion 17-g119dx RAM Replacement: passo 2, immagine 2 di 2
    • In the upper left hand corner, slide the bar with the lock icon to the right. This will unlock the battery.
  3. HP Pavilion 17-g119dx RAM Replacement: passo 3, immagine 1 di 2 HP Pavilion 17-g119dx RAM Replacement: passo 3, immagine 2 di 2
    • Slide the bar with the battery icon, on the right of your laptop, to the left to release the battery.
  4. HP Pavilion 17-g119dx RAM Replacement: passo 4, immagine 1 di 2 HP Pavilion 17-g119dx RAM Replacement: passo 4, immagine 2 di 2
    • Grab the battery and remove it from the laptop.
  5. HP Pavilion 17-g119dx RAM Replacement, RAM: passo 5, immagine 1 di 3 HP Pavilion 17-g119dx RAM Replacement, RAM: passo 5, immagine 2 di 3 HP Pavilion 17-g119dx RAM Replacement, RAM: passo 5, immagine 3 di 3
    • Remove the twenty 6.5mm screws using the Phillips #00 screwdriver.
    • Two of these 6.5mm screws are covered by a silver sticker. Remove the sticker by gently scraping your finger nail under the sticker and then remove the screws.
  6. HP Pavilion 17-g119dx RAM Replacement: passo 6, immagine 1 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 6, immagine 2 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 6, immagine 3 di 3
    • Remove the black corner covers on either side of the battery to reveal four additional 6.5mm Phillips #00 screws.
  7. HP Pavilion 17-g119dx RAM Replacement: passo 7, immagine 1 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 7, immagine 2 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 7, immagine 3 di 3
    • Remove the four 6.5mm Phillips #00 screws that were underneath the black corner covers.
  8. HP Pavilion 17-g119dx RAM Replacement: passo 8, immagine 1 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 8, immagine 2 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 8, immagine 3 di 3
    • On the right-hand corner of the laptop, remove the CD-ROM by pressing the small button on the side. Pull it out of the laptop, and set it to the side.
  9. HP Pavilion 17-g119dx RAM Replacement: passo 9, immagine 1 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 9, immagine 2 di 3 HP Pavilion 17-g119dx RAM Replacement: passo 9, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Tool
    $1.99
    Compra
    • Make sure that all screws and the CD-ROM Drive are removed before trying to complete this step to prevent damaging your laptop. During this step, you will likely hear loud crackling noises. This is normal.
    • Flip the computer back over with the screen facing up and open the laptop.
    • Use the Plastic Opening Tool to separate the face plate from the backing.
  10. HP Pavilion 17-g119dx RAM Replacement: passo 10, immagine 1 di 2 HP Pavilion 17-g119dx RAM Replacement: passo 10, immagine 2 di 2
    iFixit Opening Tool
    $1.99
    Compra
    • After running the Plastic Opening Tool along the sides, you can gently lift the keyboard up and on top of the screen to access the RAM.
    • The RAM will be located above the Motherboard and next to the Processor.
  11. HP Pavilion 17-g119dx RAM Replacement: passo 11, immagine 1 di 2 HP Pavilion 17-g119dx RAM Replacement: passo 11, immagine 2 di 2
    • Release the RAM by pulling the two white levers away from the sides of the RAM.
  12. HP Pavilion 17-g119dx RAM Replacement: passo 12, immagine 1 di 1
    • Pull the RAM up and out of the laptop to remove it.
    • When reassembling, be sure to insert the RAM at the same angle it came out. Then push it down into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
Ddr3 or ddr4?
Andres Toro - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,606
