Salta al contenuto principale
HP Pavilion 17-f127ds Optical Drive Replacement
Cosa ti serve
  1. HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion 17-f127ds Optical Drive Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: passo 2, immagine 1 di 2 HP Pavilion 17-f127ds Optical Drive Replacement, Optical Drive: passo 2, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove the screw holding the Optical Drive in place. It is located near the center and vents of the laptop.
    • Use a spudger to help unseat the drive. Pull the drive out from the laptop.
  3. HP Pavilion 17-f127ds Optical Drive Replacement: passo 3, immagine 1 di 1
    • If you need to replace the bracket on the Optical drive, remove the two Phillips #0 screws holding the bracket in place. The bracket can be placed on the new drive.
Conclusione
Stephen Brown
Membro da: 10/18/17
201 Reputazione
2 Guide realizzate
UW Tacoma, Team S3-G1, Liner Fall 2017 Membro di UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Membri
4 Guide realizzate
Un commento
I can’t remove the HP Pavilion 17-x016ds Optical Drive. NEED HELP. Is it necessary to remove it in order to remove bottom panel to replace HDD with SSD? Also can’t remove bottom panel.
Nick Koriakin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 17
Tutti i Tempi: 966
