Salta al contenuto principale
HP Pavilion 17-f127ds Keyboard Replacement
Cosa ti serve
  1. HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, immagine 1 di 3 HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, immagine 2 di 3 HP Pavilion 17-f127ds Keyboard Replacement, Battery: passo 1, immagine 3 di 3
    • Before starting, please turn off your laptop.
    • Slide the battery lock latch, the latch on the left, inwards.
    • Slide the battery release latch on the right inwards to release the battery.
    • The latch may require significant force to slide.
    • Lift the battery up and remove it from computer.
  2. HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: passo 2, immagine 1 di 2 HP Pavilion 17-f127ds Keyboard Replacement, Keyboard: passo 2, immagine 2 di 2
    • Flip your laptop over on a firm surface.
    • Using a Phillips #1 screwdriver, remove the thirteen screws on the back of your laptop.
    • Flip your laptop back over.
  3. HP Pavilion 17-f127ds Keyboard Replacement: passo 3, immagine 1 di 3 HP Pavilion 17-f127ds Keyboard Replacement: passo 3, immagine 2 di 3 HP Pavilion 17-f127ds Keyboard Replacement: passo 3, immagine 3 di 3
    • Using the opening tools, separate the keyboard from the laptop by prying it from the base along the sides of the laptop.
    • With your fingers, disconnect the keyboard connector and the connector cable from the motherboard.
    • Be careful not to lift the keyboard too high because it might rip off the connectors.
    • Carefully remove the keyboard.
Conclusione
Altre 2 persone hanno completato questa guida.
Alissa Tu
Membro da: 10/18/17
284 Reputazione
2 Guide realizzate
UW Tacoma, Team S3-G1, Liner Fall 2017 Membro di UW Tacoma, Team S3-G1, Liner Fall 2017
UWT-LINER-F17S3G1
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,140
